Citabria VG’s ?
Gillie
Roundup , MT
Wondering if any of the members here have experience with them on the 7GCBC wing ?
How do they really affect slow speed performance ?
I am considering the Micro brand .
So I hear. I fly a lot of Cubs and in the olden days C-180s with and without - AMD and Micro. I may not be the world’s best test pilot, but I spend a great deal of time at 40 indicated. I do not feel the difference.
I was able to feel the difference when we put a cuff on the 180 wing.
It is hard to get my Citabria to stall. Just saying. I bring it in at 60 with flaps two. It will easily do fifty. I’m a little pussy to go slower. Plus the stall warning is going off intermittently. 😬😬
I bring my Decathlon in at 60 - doesn’t seem to know I forgot to glue on the VGs. Doesn’t have flaps.
🤔 I’ve always thought that the stall warning was set a little high in mine. It sounds intermittent at 55 or maybe a little faster in bumpy air. Feels like it’s flying fine. Still a little disconcerting. If I come in at 60 it floats a lot. Just saying. Over the fence at around fifty it does just fine in relatively calm winds. I always make darn sure that the ball is centered at low speed!! BTW 60 is fine for a X-Wind...
i think the stall warning vane has mounting slots instead of holes so it can be adjusted a little bit.
disclaimer:
Sec. 91.3
Responsibility and authority of the pilot in command.
(a) The pilot in command of an aircraft is directly responsible for, and is the final authority as to, the operation of that aircraft.
(b) In an in-flight emergency requiring immediate action, the pilot in command may deviate from any rule of this part to the extent required to meet that emergency.
(c) Each pilot in command who deviates from a rule under paragraph (b) of this section shall, upon the request of the Administrator, send a written report of that deviation to the Administrator.
Sadly, there is no FAR that applies to taking advice from an internet forum and then flying your airplane after applying said advice so FAR 91.3 it is! :ROFLMAO:
Is that a legal disclaimer?
Stall warning devices always go off well before stall. I am not at all sure why the Decathlon even has one, but I think a properly functioning Decathlon unit will be on during approach and initial climb out.
Not sure why mine no longer does that - deafness and a good headset? I should probably look at the breaker now and then. Or clean the bubble gum out of the slot.
Remember the new approach to stall maneuver? Recover at the first hint . . .
My Decathlon horn goes off pretty close to the break. Maybe 5 mph above. It never goes off except when I stall or spin deliberately. See 0:25-0:33 of video for example.
In the 737 we would recover at the shaker, well above the actual stall. Later on, in training/Sim we took it all the way to the stall, at different altitudes. And flap settings. The amount of aerodynamic warning we got was a real eye opener.
One other thing I just noticed. If you watch the bottom of the screen, my RC Allen electronic AI is visible during higher G maneuvers. The camera mount must flex some. If you watch the last few seconds of the video, you will see that the AI finished the sequence in reference. I think it lost reference and tumbled for a few of the more complex maneuvers, but righted itself in between maneuvers. I have heard that some of the other AI's will lose reference in a prolonged turn. This is a pretty good vote of confidence for RC Allen devices in IMC ... IMO.
