jkh
So, in a previous thread I asked about "the best way to start a 2014 8KCAB" since I had one checklist that showed priming with the fuel pump for 3-4 seconds with mixture rich (of course) and then starting with mixture lean, then jumping to push the mixture in after start. The other checklist shows the same steps except that you start with mixture rich and obviously don't change it.
So I thought I might try an experiment with my 2014 cold, and it starts fine either way. I literally can't tell the difference, other than needing to jump rapidly onto the mixture knob after start with "procedure A" vs "procedure B". For a warm start, it's always been mixture rich with maybe 2 seconds on the fuel pump to prime it, which also works just fine.
Obvious question: How did this whole "start with mixture lean" for cold start procedure get into some of the 8KCAB checklists? Was it to prevent some scenario, like an engine fire on start, observed in some very rare number of cases or is there some strong mechanical argument to be made for doing things this way? Thanks!
