The 5-143 rib is the standard Aeronca / Citabria wood spar tip rib. The 4-1030 rib is also a wood spar Citabria rib, used to mount the fiberglass wing tip. From photos, it appears that the 4-1030 rib is a modified 5-143 containing 1.5" width sheet metal strips along the top and bottom cap strips of the rib, along with a modified rib trailing edge. The fiberglass wing tip is attached to those sheet metal strips. Champion fiberglass wing tip conversion kit #196 calls for the 4-1030 rib. The Citabria parts manuals, up to 1994, also specify the 4-1030 rib.
