I flew my 46 Champ 7AC today at 17 deg outside temp after installing an oil sump cover along with the oil cooler cover and block off plates for the cowel intakes. I also installed a Cyl temp guage on the RH rear cylinder. The cylinder temp reached about 390-400 deg. Oil temp was 155 deg and oil pressure at 28 deg. I think I got the right combination for winter flying. Oil pressure was at 35 PSI on the ground but dipped to 28 with the warmer oil temp. I use 20-50 in the winter. May get a little more pressure if I went to a higher weight oil but I think I'm OK as is. Anybody have any input, I would be interested. Below is the pics of the cowel plates.
Thanks.
Thanks.
