The standard 4412 airfoil stamped .020" aluminum ribs were used starting with the first 7AC. It seems as the models progressed, the wing construction did not change as indicated in Champion service letters 56, conversion from 7AC to 7EC, letter 60, conversion from 7EC to 7GC, which had progressive gross weight increases from 1220 to 1650 lbs and using the same wing. Some time in the 1960s, Champion went to a .032" stamped aluminum rib. Does anyone know which 7 series model first used these thicker ribs?
