Aircraft is located at Alexandria Field, Pittstown, NJ.
1968 Champion Citabria 7ECA, certified in both the utility and aerobatic categories.
Here's the quick and dirty;
2456 TT airframe
905 SMOH Lycoming O-235-C1 (2400 TBO, OH'd in 1997)
Prop was overhauled in 2019, about 85 hrs since overhaul
Complete logs (Adlog system plus original log books)
Empty weight 1105, gross weight 1650, 26 gallons total fuel
Milman aluminum spars and leading edges STC's about two years (85 hours) ago
Olin Pash aileron spades STC
Whelen LED combo wing tip nav/strobe lights
New fabric/paint on wings, new paint on fuselage and tail
Reconditioned gear legs
Master cylinders rebuilt at annual
New motor mounts Jan, 2022
Exhaust manifolds both completely rebuilt from the flanges by Dawley about 125 hrs ago
Tailwheel disassembled and inspected, reassembled with freshly powder coated main components, new tailwheel spring, tire, and tube
B&C spin on oil filter adapter STC
Brackett air filter STC
Controls rebuilt (all bushings and hardware) 2020
No play in tail hinge bushings
Front and rear shoulder harnesses
Tanis electric pre-heater (oil sump and cylinders)
Good glass
Good tires
Landing light and interior instrument flood light
Door removal STC
Wired for a battery tender
Garmin SL40 comm/intercom
Uavionix TailBeacon ADS-B out
King KT76A transponder
The new zipper in the headliner will be finished as soon as it's warm enough outside to do the stitching in the vinyl headliner.
Log book pages added below aircraft photos section.
Annual just completed Jan 2, 2022
Asking $59,500, can deliver if necessary
2456 TT airframe
Good glass
Good tires
Door removal STC
