My 2004 8KCAB Super Decathlon is currently in annual, and my mechanic suspects the left fuel tank may be leaking. I'm hoping to get some advice on what to check, and also recommendations for a good shop in case the tank needs to come out for repair or replacement.
Over the last year I've occasionally noticed dried blue fuel dye on the underside of the left wing, seeping through small cracks in the paint and leaving a pattern as if it has been blown by the wind toward the tail. I think it tends to appear after I accidentally overfill the tank, and possibly after aerobatics (including inverted flight). I don't see any logbook mention of the fuel cap or gasket being replaced, so I'm also wondering if this could just be fuel sloshing around, getting through a worn fuel cap gasket rather than a leak in the tank itself.
A few years ago, the left tank was removed and repaired (not replaced) by a prior owner, then reinstalled. I've only flown the airplane for about a year. I've never seen active dripping while the plane is parked (no puddles in the hangar), but the dried blue dye under the left wing has shown up a few times over the year.
Any thoughts on likely causes or common trouble spots? And if replacement ends up being the best option, I'd really appreciate recommendations for a reliable shop that can handle the tank work, recovering, and painting.
Thanks in advance!
Thanks in advance!
