- Joined
- Apr 4, 2018
- Messages
- 3,979
We have a Decathlon that generally takes a half hour to get underway from the time the towbar is removed to brake release. It has not caused me any serious delay, although I can foresee problems - but the taxiway leads to several corporate jet and turboprop hangars so it could become a problem for some folks. It did delay a T-34 for five minutes a couple days ago.
I decided that maybe I was not cutting enough slack for avid checklist users, so I timed myself using the honest-to-God AFM checklist for my aircraft - a 1977 version with the 180 hp engine. Page 17.
Five and a half minutes from removing the towbar, to brake release. That included checking oil and dipping fuel, a walk-around (not using the POH checklist, which could take a while), fastening myself in with no fewer than seven straps, and reading the AFM checklist to make sure I remembered to turn the mags on and press the starter button. It even tells me to release the starter button after engine start.
There are five items in the pre-start checklist, including some pretty good ideas - seat belts, fuel, radios. Fifteen seconds with the page in my lap. Then, for engine start there are nine items, the most important of which are to check outside for stray puppies, and check the oil pressure after you read the part about releasing the start button.
30 seconds of reading and answering, given that I released the starter button before I read that item and answered it. Sort of a combination checklist and "do-list."
I did time the J3 prior to that - it took me eight minutes from releasing the towbar to releasing the brakes for taxi. A little longer than the Decathlon, but then I did have a discussion of pattern altitudes with a neighbor in the middle of my walk-around. I did not time that, but after a few minutes I grabbed my jacket and jumped in - I wanted to fly.
The Decathlon has a POH, which is different. Pages 3-6 and 3-7 have the checklists - seven items before start, including closing the door, putting seatbelts on, and setting the brakes. All good ideas - two more than the AFM.
Then there is a 20 item "do-list" for engine start. I did not have the POH with me, since it is not required - but might try it out later, for timing. The starting checklist asks you to make sure you put your seat belt on, and close the door - so I sense a bit of redundancy here. But hey, if you don't get it right the first time, be sure to have a second checklist to check your first one. I suspect it might take a minute to go through all 20, including the one that tells you you have to release the brakes to taxi,
so let's say it takes a full minute from start to finish, with one finger on the checklist while you are turning the mags on and pressing the start button with the other hand.
None of this adds up to more than ten minutes blocking the alley.
