Decided to try to finally get these to stop leaking while we're doing the annual this week. These are the Cleveland 10-5 master cylinders with integral reservoirs and parking brake valves. There's not much out there about these valves so I took some photos and tried to explain how the rebuild went.
Here's the master cylinder installed under the floorboards. You can see the heel brake pedal sticking up through the floorboard on the right.
Start by opening up the hydraulic line in the back left of the photo. Then unscrew the blue AN fitting and pry out the little spring and plunger that are being held in by the AN fitting. That block like appendage hanging off the side of the cylinder is the parking brake valve, unscrew the nut and twist/push the pivot shaft out the top. You might have to turn the parking brake pivot shaft to get it out, I'm not sure what the trick is but it didn't just pop out. If the plunger is stuck in the there then there will be interference, turn, push, turn, push some more, it will eventually pop out.
Brake line disconnected
View of the top of the master cylinder, that return spring for the parking brake has to be disconnected too at some point.
That's the pivot shaft of the parking brake dangling in place after being pushed out the top. It acts a lot like the cam shaft in the more common Gerdes parking brake valves that are bolted to the floorboards of later Citabrias and Decathlons.
The green tube is an extension that allows the aft end of the master cylinder to be attached to a frame member and the forward end of the tube to be attached to the bottom of the brake pedals. It has to be removed from the brake cylinder shaft so the packing nut can be slid off the plunger shaft. Chances are, the holes for the pin are pretty out of round. Use an awl or something through the plunger shaft and unscrew the nut and threaded end that were attached to the extension tube.
Unscrew the packing nut and slide the plunger assembly out. The packing nut has an o-ring on the inside.
View attachment 4596View attachment 4597
At the other end of the shaft is the actual brake plunger. There's an o-ring on the outside and a plastic washer buried under the plunger. There's a really fragile snap ring of some sort holding this end together, if you decide to go looking for the plastic washer be really really careful removing the little snap ring keeping that end of the assembly together. The photos should explain it.
View attachment 4594View attachment 4598View attachment 4591
There is an o-ring on the shaft for the parking brake valve and another inside where the parking brake shaft goes into the housing. I'm pretty sure that those two parking brake o-rings weren't changed when my cylinders were supposedly rebuilt which is probably why they continued to leak.
Here it is all back together, cleaned up and ready to go back in.
Part tag from Planepartsinc.com and the assembly lube I used. The rebuild kits I used were about $30 each.
View attachment 4593View attachment 4588
Hope that helps!
