Champ Alternative to Imperial 104HD Fuel Shutoff Valve - 7BCM
Sully, That Piper SL944 addresses the piper valve with a plastic tapered ball plug versus the Citabria's brass tapered Ball Plug. EZ Turn (used to be called Fuel Lube) is the better lube choice for the Citabria valves. Also that valve uses an O'ring for the cover while the Citabria valve uses a copper flat ring gasket.
