- Joined
- Apr 4, 2018
- Messages
- 4,196
I need to disagree a bit on the 337. You need 337s for major repairs and alterations. The regulations explicitly exclude things that are on the type certificate.
My impression is that that means if the factory is delivering aircraft equipped with breakers, props, or engine monitors, and you do the same, it becomes by definition a minor alteration. 337s are not permitted for minor alterations.
But Hiper is correct - nobody looks at 337s anymore. You can type up a 337 to put an O-470 on a Champ, and no inspector will ever see it until the aircraft crashes. File early and often?
