The red connections are the ones I have to make. The span at the breaks in the bus rod is not going to be a lot, maybe 1/2 inch. And there won't be a lot of remaining bus rod to work with, probably also 1/2". Is there any kind of short crimped sleeve or ring I could use to make a mechanical connection between the wire and rod?
The last avionics shop soldered a wire to the junction between a fuse holder eyelet and the bus rod. Maybe that would work?
