- Joined
- Apr 4, 2018
- Messages
- 4,333
Do full stall landings in that bird. I don't teach wheel landings until full stalls are completely mastered.
I like that! I think a nice full stall landing is harder than a wheel landing...Do full stall landings in that bird. I don't teach wheel landings until full stalls are completely mastered.
Just a thought but the point at which an elevator becomes ineffective is not the same as when the rudder becomes ineffective. There is a moment in which the rudder becomes ineffective transitioning from tail high to the ground which has to do with the air flow around the rudder being disturbed as the tail drops until the wheel is steering. But the speed of the tail dropping is greatly changed having someone in the back vs solo. You could push the plane side to side yawing it on the ground with two fingers, but you can’t lift it with two fingers! Then put a person in the back, can still move it with two fingers but definitely can’t lift it.I think the key here is that you were "keeping the tail off as long as possible". When the tail falls on its own, that means that your elevator is no longer effective(won't hold the tail up any longer).
If the elevator is no longer effective, then neither is the rudder. You got to the point that your rudder would no longer steer the airplane.
You should start the tail down as soon as speed will allow. Get the tailwheel on as soon as possible to help steer the airplane.
Here is a paper I hand out to my students, hope it helps.
https://www.advancedtailwheeltraining.com/tailwheel_basics
So many rules! Oh wait...I think the key here is that you were "keeping the tail off as long as possible". When the tail falls on its own, that means that your elevator is no longer effective(won't hold the tail up any longer).
Good point about the elevators giving away what is happening to the rudder. I did wheel landings a long time ago when I first got my tailwheel signoff and not much since then so I'll have to admit at taking a look at your handout also!I think the key here is that you were "keeping the tail off as long as possible". When the tail falls on its own, that means that your elevator is no longer effective(won't hold the tail up any longer).
Saturday work on getting the tail wheel on the ground first - before the mains.
I have to watch my students - they start getting grease job wheel landings and forget the full stall. Wheel landings can be smoother - but a good solid "plunk" on 3 wheels is ok, and actually preferable to a steady diet of wheel landings.
I have an exercise you may not have seen before - I get the stick and power; the student gets the rudder pedals, and I try to get them off the centerline for about 2000'. Great fun!
Even with that statement, even with so much more area, the tail will still drop faster when someone is in the backseat. Does airspeed required to use the rudder change?probably why there is so much more elevator area than rudder usually, no?
For us east coast guys, what’s wrong with runway 28 at your airport?Stay off 28 left until you have 50 solo pattern hours.
I am embarrassed to say I did not caution a student that way. He had 42 hours in Cubs, not all in the pattern, but maybe ten solo pattern. Got one tire in the dirt on the left, hit one of those huge signs that are now everywhere, and flipped upside down.
Unhurt, but he quit flying. That was two years ago, and I still regret not insisting . . .
