- Joined
- Apr 4, 2018
- Messages
- 4,333
The problem with Cubs is the aileron hinge line is both below the bottom of the wing and below the bottom surface of the aileron. A teeny difference between left and right will allow a significant difference in torque due to wind force on the aileron face.
I believe the Decathlon hinge surface is above the bottom edge, and the top of the Dec ailerons have a gap seal. I can look today -
So in the case of hands-off asymmetrical aileron deployment in a Decathlon - start with the spades. Make sure both are aligned equally with the ailerons. The other (remote) possibility is mismatched ailerons themselves. They build them in precise jigs.
There is no "cable adjustment" that can fix this sort of problem - don't even try to center the stick until you can fly hands-off with ailerons equally trailing. And for the Cubs, the asymmetric force is so strong that even a two foot long trim tab couldn't cure it.
Difficult to believe a factory test pilot would not notice this . . .
