This very specific question is for anyone that has installed the Milman conversion. Did you find most of your bolts were too short?
Milman specifies that the compression struts should use the supplied AN4-13A bolts instead of the -12A the parts book calls for.
Ok, but the aileron brackets, sector bracket, large ribs, etc also seem to be not showing enough threads. Do all bolts need to step up a dash size????
Here are some photos. Most of these are just a TIGHT snug, but I won’t get much more turn when it torque.
