Champdriver
I saw the bushings listed at Univair for $32 each. I don't know if that is for a set of two or not, I would assume a set but call to make sure. You'll need two per stick socket. There is no shim for the stick to socket on the top, it should be a tight fit with a long AN 3 bolt.
The original part numbers are, AN 2550 for the side stick socket bushings. AN 945-6P for the large washers, and a AN 6-25 bolt. If you're going to replace the bushings replace the bolt too.
