I used bottle jacks on top of a stack of dunnage ... crossed 4x4s and plywood squares. The ACA jack adapters help a lot. I secured the tail and wings with takedowns and put the tailspring up on a jackstand. I'll post some pictures later.
Woke up this morning and the wind was honking. Plane is currently in a shade hangar so I freaked out a bit. Went to check and it was fine. Structure at the end shielded it. I tightened everything up good to make sure. Hopefully will have the gear back on by Tuesday, after I paint them, though I am still considering ordering reconditioned legs from rainbow Ron.
No problem getting anything out of the frame. The only sticking point was the thru bolt and the gear leg. I will be careful to use antiseize when I assemble. I think maybe paint in the holes might have caused it to freeze up, so I will clear that out before assembly..
