Thank you for the information. I apologize in advance for all the questions, but I have Wing Gap cover parts for several airplanes (multiple paint schemes), and only one part (3-451) matches the dimensions from the blueprint. The airplane was taken apart in 1999; I was not there; I started this as a basket case, and I am not sure how to verify the left from the right part.
Part # 3-451 (top-first) is the first Wing Gap part. Does the straight end go against the fuselage or the wing? There is a large bend in the part, so I suspect it is bent around the front of the leading edge, but I am not sure where the ends of the part should end on the top and bottom of the wing. The second Wing Gap is #3-452 (top-middle), a straight, flat part that appears to have been attached mostly with silicone adhesive. Is this the way to avoid screws into the spar? The third top Wing Gap part is #3-453 (top-end). I believe this is the part with the fold that you mentioned in your post. Is this all the wing Gap Parts on the top? The second Wing Gap is #3-455 (bottom middle), and it has a flange. How does the flange fit? When lining up #3-453 (top) and #3-455 (third bottom), do they completely cover the end of the wing? Thanks in advance for your help.
