I could never find out the difference between 7EC and 7ECA. That being said I had an O-200 powered Citabria that weighed 1045#. I don’t want the O-320 engine ones because they burn more fuel and I just want to putz around the area. Plus the big engine Citabrias have less useful load but need to carry more fuel thus less payload. I weigh 200# and want to carry another adult. I realize I will need to reduce fuel but would like to carry at least 25 gallons. I’m looking at one that weighs 1115# and was wondering if that’s about normal or might I find other 115 hp ones that weigh less?
I had similar thoughts - until I thoughts more about it.
The 7ECA wins on *legal* useful load. However, I fly out of a 1800' grass strip that tends to be very sandy and soft, with 80' trees at each end. On a hot humid day when the DA is up around 3000' (at a 50' field elevation) I'm very happy having a shorter take off roll and a solid 1000 fpm rate of climb at gross weight.
In a 7ECA I'd be looking at 200-300 ft longer take off rolls and a rate of climb around 600 fpm under those hot summer day conditions. I'd probably still make it over the trees, but it would be one of those keep it low and accelerate in ground effect before pulling up over the trees departures. I'd also be just over the trees with trees under me for almost half a mile in one departure direction. An engine failure in that first 30 seconds would put me in the trees, while the vulnerability in the 150 hp 7KCAB is just a few seconds.
Now...there is no free lunch, but the cost of of that lunch is still pretty cheap. the O-320 burns about 12.5 gph in climb at full power with a full rich mixture. On a standard 60 degree day it'll average about 1000 fpm from 0 to 4500 ft, so about 5.5 minutes at full power for take off and climb. That's about 1 .15 gallons of fuel. Once at altitude, I can throttle back to 2150 rpm and cruise at 100 mph burning about 5.3-5.4 gph leaned 100 degrees ROP for a 2 hour 200 mile leg that's about 12 gallons of fuel total.
In a 7ECA the full power full rich fuel burn is about 10 gph, but the average rate of climb will be around 600 fpm. The time at full power will be longer, and the resulting fuel burn will be about 1.25 gallons of fuel. At 100 mph the 7ECA will burn about 4.5 gph leaned 100 degrees ROP and a 2 hour 200 mile flight will have a total fuel burn of about 11.5 gallons.
Consequently the greater take off and climb performance only costs me a half gallon of fuel - when I fly the 7KCAB at the same airspeed as the lower powered 7ECA. You'll find that's true in pretty much any aircraft where different sized engines are installed in the same basic airframe (Comanche 180, 250, 260, 400, Cherokee 140, 160, 180, etc) - fly them at similar speeds and you'll get similar fuel burn.
The lower powered aircraft are slightly more efficient, but that efficiency increase is a lot smaller than you'd think. Unfortunately, that reality gets lost in performance numbers that use 75% cruise numbers, where more power equals more fuel burned. Best range is usually found in the 50-55% power settings, and on a draggy airframe like a Citabria it takes a lot of power and a lot of extra fuel to go significantly faster. It's usually not worth it. On the above mentioned 200 mile flight, 75% cruise in a 7 KCAB will get you there in about 1.5 hours at 130 mph, at about 11 gph with a total fuel burn of about 18 gallons (6 more gallons to save 30 minutes).
