Bipbuilder
I have a 7kcab with io 320. Right tank is consistently burning more than left. Replaced fuel caps with new sealed caps and lubed gaskets. Same result.
Placed aircraft in flight attitude with caps on. Both tanks full.drained 5 gallons from engine sump and found right tank 1 gallon lower than tight tank. Drained another 5 gallons and right tank was 2 gallons lower than right. Repeated test but with fuel caps off and got same results.
Unsure of what else to check.
Also was wondering if the left tank ran out would the right tank continue filling the header tank?
