Howdy,
One thing I found about the 8:50x6 tires is it gets the nose up a bit higher, making for a slower STOL configuration close to the ground as you can have the tail touch first and mush the mains down onto the low pressure, pollow soft main tires.
Been going to the STOL Competitions (Only as an observer) and talking to the pilots, they say getting the nose up higher is the trick for them very short landings. That's why a lot of Citabria pilots are putting on the Aluminum Scout gear, Taller and lighter.
My technique is getting better but you have to admit that a 7ECA w/ 115hp is underpowered especially when hot, humid, high density altitude, loaded to gross, as so forth.
I did see a 7ECA almost identical to mine, (Many Years Ago) that had VG's, 31 tires, and Aluminum Scout gear. Nose was pointed up 10 degrees higher than stock! I would watch him come in and drag the tailwheel, back down the power till nose started to drop and add some power to soften the mains on touch down. He was quite talented.
Wish I knew who it was but he was from New Brunswick, Canada.
I wish I could make such graceful landings as I have seen him perform. Takeoff was impressive, he would add power, tail up, get speed, and rotate in ground effect flying 3 ft off the ground at that nose high attitude till speed increased. I think he also had a climb propeller, or beyond. He said he only cruised at 80kts, which would be about right.
Anyway, something to think about. Grass always looks greener on the other side of the fence. But, my grass is green enough for me so far.
Ken "COWBOY" Winiarski
Cowboys Air Ranch (84ME)
