Yes. I think three companies make 6, 7, 8, and 8.5 for 6” wheels TSO.
And good recommend for a 8”?
Like something low that light weight tundra I linked, but smaller
Thanks
I think ours are Goodyear, but I will look. I think if weight is the issue, Desser can grind some rubber off. We are at sea level, and the difference in weight between 8:00x4, 8:00x6, and 26” blimp tires was just not noticeable. 85 hp J-3.
Here is the deal - Grove has an STC for Pipers, from J3 all the way to PA-20, in both 1 1/4" and 1 /12" axles. They are TSO, so getting an approval for a Champ should be no big deal. I have done it locally, and Grove has copies of my 337s.
$3300 today's pricing, not including tires. They are approved for all common sizes.
I really don't know why 8:50s needed an STC on standard Cleveland wheels - they fit, and the only issue is the brake disc may rub on the tire. We ran 8:50s on Cubs and Cessna 180s for years, without worrying about approvals. Good thing the statute of limitations has run out. We never had any problems at all.
I can’t find the STC itself. But its held by Northland Aviation in Fairbanks AK.
Yeah, you will be replacing those. Do the research on hydraulic brakes.
