vupilot
Since obtaining my 1975 8KCAB one thing I have not been happy with is the below 1300rpm operation of the engine. My mechanic and I adjusted the idle mixture and settled on a setting a little bit leaner but such that I still get a little rpm rise on shutdown. Cleaned servo screens and new o-rings. Checked for induction leaks, none found. I get a little lesser than a smooth purr at 1000 rpm than I'd like. It has a slight stumble or lag betwen 1000-1200 rpm when advancing the throttle, once through that it runs great from 1300rpm on. I remember from back when I instructed in 8KCAB's years ago in a 1999 & 2001 model they didn't idle as smooth as carbureted engines either, especially when hot, but this one seems slightly worse than I remember. My 2200hr engine was swapped in 2020 with a 200 hr SMOH engine and the log doesn't say where the Fuel Servo came from just "installed fuel servo" doesnt say if it was swapped over from the old engine or if it was new in 2020. There is no log entry I can find of a fuel servo overhaul. I read the fuel servo should go about the life of the engine between overhauls. An exchange unit is about $2500. Has anyone recently had their fuel servo overhauled, does it save anything over just exchanging? I think I will have my mechanic clean the injectors first but looking into options if that doesn't improve things.
