BB57
- Joined
- Feb 20, 2020
- Messages
- 210
It took me a minute or two to figure this one out...
Awning fabric is no more or less UV resistant than any other fabric. .../
It is sacrificial but over a 5 -10 year period depending on the fabric, where you live and how much exposure to the sun it receives. If you live in a dry, sunny climate like the desert southwest, then you want the best UV protection you can get. If you live in a cloudy, wet climate like the Pacific Northwest, then you want to place a premium on water repellent traits. If you live in the south where it's hot, humid and often sunny, you need both plus great mildew resistance. If you live Florida, which has all the downsides of the south plus salt air hitting you from both sides, you just need to move.
Polyester fabric used on aircraft, whether it is called Ceconite, Stits Poly-Fiber, or Superflight is coated with UV inhibitors to extend the life of the fabric. If the aircraft is hangared, the structure under the fabric will probably need attention before the fabric itself goes bad. Similarly, high quality awning fabric also has UV inhibitors in the top coating to both extend the fabric life and protect whatever is underneath. Which is to say not all fabrics are equally UV resistant.
Even with the same polyester or vinyl-polyester composite fabric, lighter colors will reflect UV rays better than darker colors, and the surface will stay cooler. Those are two of the reasons that you often see white so prominently used on aircraft, especially fabric covered aircraft and composite aircraft. For composite aircraft it is more often than not a certification requirement and you'll find composite aircraft with temperature gauges on the spars, with a prohibition against flying if the spar temperature is too high.
The same applies to covers. I used blue on my motor glider covers because a) it was aluminum and not composite, and didn't have the temperature issues, and b) It came off the same roll of fabric I bought for the boat project and was more cost effective. But....if I were making covers for a fabric covered aircraft I'd use a light color, like a light gray, which reflects light well, but also doesn't show dirt as bad as white.
