Wanted: AEIO-360-H1A/H1B
justrhines
Texas
In search of an AEIO-360-H1A/H1B, core condition or otherwise. Let me know what you've got!
Justin
903-340-6711
FWIW, the case for an AEIO-360 and an AEIO-320, as they were used on Bellanca Decathlons, are the same part number. If you have a -320, you may be able to find an engine builder that will convert it to a -360 but you will need to buy everything from the crank, sump, cylinders and in between
Check the part number on your -320 case and go from there to see if it is the correct case. This may be for rear mount governors only, I’m not sure.
We have an O-360 C4P - 1200 hrs since new, but bent crank and two bad cylinders. Unsure of its value - If the crank and cylinders were ok, I was guessing $20 grand. Is it worth anything? lycoming logbook.
