Backside (frontside?) of the panel, started wiring and figuring out the remaining details. The basis for the set up is the ACA electrical system drawing that I purchased from the factory combined with the schematic in the parts manual for my '77. The main power feed from the alternator/battery side of things will attach at the crossover links the two bus bars and then power will exit out the top of the upper switch breakers and CB's and also out the bottom of the lower CB's. The factory set up is very similar, just different for the specific equipment that they'd put in a new plane like a Garmin G3X which I'm not using.
By the way, all of this work uses up way more wire than you'd guess when you're first ordering stuff!
