Ed,
Here's the long answer, I originally was working towards an aluminum placard with an anodized print that would be nearly indestructible, like a motor data plate. The shop I was working with first sent a matte finish label with low res graphics (they asked for a 300 dpi jpg file
) that was easily marred and then they sent a nice label but it was oversized. In dealing with them they were kind of rude so I asked for my money back (about $120 for the one label!) and moved on.
Next best option would be a silk screen so I got to work giving that a try. I made a nice screen but couldn't get the ink to lay out evenly across the whole field. I tried screening with Rustoleum enamel for durability and then opted for a screen ink which would require a clear coat.
I had been trying to avoid having to clear coat it but I couldn't get either ink to work and didn't want to keep wiping the powder coat with mineral spirits so it was on to the next option, which I had been trying to avoid, vinyl. A local shop tried to cut my graphic from white vinyl but the text was too small. That left print-on-vinyl which was the lowest form on the schnazzy scale but I didn't have any other options. Callie at callie-graphics.com sent me a bunch of labels but she didn't have the font I used and I neglected to send the file with the fonts outlined so I didn't like what she sent.
As I tried to work with her to get it fixed, it occurred to me that since I now accepted I'd have to clear coat the panel, I could try making my own print-on-vinyl graphics as a way to check my work before Callie did her higher quality prints. The first vinyl sheets I bought worked great and the print quality was really high. Naturally I went looking for a higher quality vinyl, found it, tried it, and it looked awesome. I must have printed twenty different labels.
What worked in the end was a gray field, white text, blue border, and a pattern over the top that I was able to re-color to match the blue border. The pattern adds a blue hue to the grey although it will probably fade a bit over time, we'll see. Adobe Illustrator was used to make the graphic and I'm pretty happy with how it turned out. I used Eastwood 2 part matte epoxy clear coat over the whole panel and it was super nice to work with after I learned the first few coats have to be light and given time to set to keep the vinyl from bubbling. The label that's on there now was put on after I bubbled the first one.
FWIW, ACA's placards are printed on vinyl so I guess vinyl is not so bad after all. I'm going to make all of my placards to match the panel and the interior is already ordered and will be that same gray with a hint of blue theme.
And one last thing, painting in the dusty old shed wasn't as bad as I was making it out to be. For the clear coat I did the extra step of wiping the panel with a tack rag and the finish came out great and there weren't any dust nubs in the finish. I was wrong thinking that wiping with alcohol and blowing it off with compressed air would be enough to remove any last bits of dust. Hooray for tack rags! lol
