I was addressing the legality question. Intro for AC 43-13.1b states that contents can be referenced by para as acceptable data for minor repairs in the absence of a manufacturer specified repair method. So first step would be checking Bellanca or ACA service manual. If nothing there, the AC is the legal source.
Chapter 3, Fiberglass and Plastic repairs, section 3.1 non-structural repairs just says use low temperature "resin". But it also recommends due to variety of materials that a destructive test be used to verify bond. In other words, mix up a batch of resin, glue a patch to the original material, then tear it off. If results are satisfactory, sand it off and proceed with repair.
Section 3.3 on structural repairs specifies "viscous epoxy resin", or so I recall from skimming it.
