flyingdakota
- Joined
- Apr 13, 2018
- Messages
- 26
I would post some pics but the wing is disassembled at this point....
Funny, I just installed these two fittings last night! I only have pictures on my phone from when I took it apart. My wing had them as you described, front ones in from the front and rear ones in from the rear with all nuts and washers on the inside of the spars. Also if you look very closely at the diagram it appears to be that way too.
Thanks for the pics! Right away I see you have a channel over the tank for the fabric to attach to, I don't have that. I see your attach point also for the tank strap is on the lower bolt so I'll have to take a look at that too. What year is your airplane and which Citabria is it? I have what Milman refers to as the "rare" 3/8" filler strip behind that nose rib between the root and 1st ribs.
Bart, have you considered adding a fuel gauge to your LEFT wing while it's not assembled? You will find it usefull the first the damn bird empties RH tank faster than you expect. Then you'll land ASAP for unsure fuel, and on the ground you'd find all your fuel migrated to your LH wing...
My stuff is showing adding 10 pounds added with the spar kit. Wish I had put the wing on scales before I took to fabric off to see the true weight difference. What does your leading edge kit add?
Re: trammeling.
Have you guys considered a string along the forward spar? Trammel one bay for squareness (important) then make sure that front spar stays dead-straight?
I always check all bays, but think straightness is the most important thing for strength. My trammel bar is a light wood strip, two pointers, and two small C clamps.
