Got the new left rear spar into place this evening. Maybe other people have had a different experience but my spars aren't sliding into place very easily. In fact, and maybe it's the primer making things less slick, I've had to tap the spars with a wood block to get them to slide into place.
Because I'm working by myself, I've had to brace everything to the table so I could tap the spar without knocking the rest of the wing across the table. I clamped a piece of wood across the top of the ribs and screwed blocks to the table to keep the rib bottoms from sliding. The whole assembly is strapped to the table to keep it from sliding.
View attachment 947View attachment 946
As the spar is being slid into place you have to make sure you are maintaining clearance in the rib openings so you aren't scraping the spars on the sharp edges of the ribs. There is only a tiny little bit of room to play with
You can also see the blocks I have in place to keep the spar aligned with the table so it isn't pointing up or down as it's moving through the ribs.
And finally, after hours of preparation and careful execution, the new spar is in place!
