Anybody seen this setup before? No logbook entry can be found.
Agree with Steve on this. It looks like the valve I got for my 1967 7KCAB from Burl. It’s a ball valve and while pricey, works well - once you reconfigure the lines and connections to it.
I had to replace my valve as it was very difficult to turn and ultimately would not shut off completely. Not what you want if you ever have an in flight fire. I took my old one apart and determined it would be very difficult to lap the tapered surfaces on the male and female parts of the valve and get an effective seal. Gunk it up with enough fuel seal and it might leak less, but it still won’t fully shut the fuel off. In my case, the spindle on the valve fractured so it made the “fix it or toss it“ decision a lot easier.
Burl indicated there were no fewer than 9 different valve variations used on the Champs and Citabrias, if you order one you’ll need to include the dimensions and the distance between the holes on the mounting tabs. He’s fairly slow (2-3 weeks) if he doesn’t have the right valve in stock, and he only ships USPS so if you are thinking of changing it, order one in advance of your next annual etc, so you’ll have it on hand. And plan to have it arrive early so you can order the correct fittings if necessary.
The good news is the valves are well made, silky smooth and very easy to turn. He also includes a new universal joint for it that uses cotter keys instead of screws.
You can also use the current valve from ACA, but in order to do that you’ll have to remove the existing tabs and weld new tabs on the tubing. That’s not bad if you have to stripped to recover, but not my idea of fun in an assembled aircraft with fuel and oil residue in the boot cowl, etc.
