FAA Order 8620.2A, Applicability and Enforcement of Manufacturer's Data
7. TCDS. Consistent with 14 CFR, a TCDS is part of a product’s type certificate (TC). A
TCDS is a summary of the product’s type design. It is used primarily by authorized persons
during initial or recurrent issuance of a Standard Airworthiness Certificate. It is neither a
regulation, a maintenance requirements document, or a flight manual document. As such, for
aircraft holding a valid and current airworthiness certificate, a TCDS should not be used as a sole
source to determine what maintenance is required or what the flight operations requirements are.
Any language on a TCDS, by itself, is not regulatory and is simply not enforceable. There must
be a corresponding rule to make any language on the TCDS mandatory. For example, there is a
mention of “operating limitations” on most TCDS. The corresponding rule for “operating
limitations” is 14 CFR § 91.9(a) which states, “Except as provided in paragraph (d) of this
section, no person may operate a civil aircraft without complying with the operating limitations
specified in the approved Airplane or Rotorcraft Flight Manual, markings, and placards, or as
otherwise prescribed by the certificating authority of the country of registry.” Without § 91.9,
the TCDS requirement to comply with operating limitations would not be enforceable.
