Sully
The 337 for my Milman spars added 10 lbs.
I need to recast this because in no way did I mean to be a jackass. I have always been under the impression that aluminum wings were heavier. If they're lighter, then that changes my opinion of them.If the Decathlon wings save thirty pounds, thereby lowering the empty weight by thirty pounds, and they increase max gross by 100 lbs, that's 130 pounds added to the useful load. You're saying they come in heavier, my Milman conversion left me lighter where everyone says they're heavier, so I'm not sure we can resolve this and I've already had to use the word "thereby" so I defer on the matter.
Love it. Bellanca $50k ACA super D $300k. Now if I can just get my backseat friends to pay for it. (Asked my wife, she said she is not that good a friend).Bellanca Super D: empty 1330, MGW 1800, useful load 470, payload with full fuel 224 = me and a bag.
Current ACA Super D: empty 1304, MGW 1950, useful load 646, payload with full fuel 400 = me and a friend.
Will the Scout gear fit? They are much taller. My Scout sits much higher than the Decathlon. In fact I had to raise my T-hangar roof because the plane is so tall (stock 8.50).I've looked hard at aluminum gear for the gcbc, but then again, I already have 2 sets of scout steal gear that I could put on it...... goodbye useful load
the scout leg is also longer at the mount. Heard of 2 ways it has been done. Re-drill the gear leg to the citabria bolt pattern or the preferred way is modify the fuselage to accept the leg as is. I understand ACA sells a kit to beef up the undercarriageWill the Scout gear fit? They are much taller. My Scout sits much higher than the Decathlon. In fact I had to raise my T-hangar roof because the plane is so tall (stock 8.50).
I'm not sure it's the steel or aluminum gear leg that fails.Getting pretty close to talking myself into aluminum gear. My steel gear are 42 years old and have 1700 hours of who knows what on them. From research, prop strikes and gear failures are not uncommon for these planes. Am liking the mental comfort factor of new, beefy, longer gear.
The aluminum gear for the Dec do not raise it.
If my old 1978 steel gear are worn out and sagging, fresh gear would raise the nose. Aluminum gear would raise it more.I spoke to Dale at the factory today about the aluminum gear legs for the Decathlon
- They're an inch longer than the steel gear
I did post that, but in the same thread I described another prop strike in another 8KCAB I was 1/4 owner of. A student learning wheel landings over controlled on the stick forward after the mains touched. The gear flexed and the prop nicked pavement. This is not the first I have heard of that type incident.For some reason I thought it was you (Ed) that posted pics of a prop strike and it has more to do with pegging the brakes at low speed while taxiing than any component failure.
I saw a figure quoted for $6500, but that was from 2013. That is a lot of money. I could get the fuselage recovered for not much more than that. OTOH presumably the gear upgrade would increase the value of my plane, especially if I later got the wings for the gross increase.
If my current legs are damaged, the alternative would be a replacement spring steel set from Rainbow. Those are $800 on exchange, with an $800 core charge. I suppose the question would be what kind of labor cost am I in for.
I started paying attention to stories about Citabria spring steel gear legs bending. Turns out it happens a LOT. I found 6 or 8 instances on the internet with a cursory search.
Hey. New UK member here - I don’t suppose you could help me with a lead for this Rainbow Ron guy? I have a bent right hand leg needs straightening…
