- Joined
- Apr 4, 2018
- Messages
- 4,333
Two weeks. Problem is the boot cowl - will your IA let you attach (maybe stitch) your new fabric to the old fabric where it is difficult to wrap it around a former? I believe it is legal, and if you do the tape right, the stitches won't show.
You might be able to do it with the wings on - that would save a day, and the very real possibility of damage.
I will study mine, and see if my advice makes sense.
I graduated, three weeks ago, to a Graco-Croix turbine HVLP spray setup. Today I left my hangar at 12:18, pedalled across the airport, stirred the Poly Tone yellow, dumped three cupfuls into the gun and put a complete crosscoat on a Taylorcraft wing, cleaned the gun, closed the hangar, and was back 8 minutes early for my 1 PM student.
If I had been using my Binks 18, I would still be there . . .
I do have a wing rotator, so it is a one-man show.
Fuselage fabric attachment goes really, really fast. The time-consuming part is the window edges and taping. Spraying is three days, if you really work at it and have something to do while each coat dries.
I now think that, with the HVLP turbine setup, two coats of silver "Poly Spray" is enough, and to get going, one coat of white and go fly. That, including spraying the second coat of Poly Brush, is four coats. I am going to do a test panel before doing the tail feathers on the T Cart.
More tomorrow. Others here are getting good results with Stewarts, but the learning curve is high. Coating through Eko-Fill is actually faster than the Stitts, but that finish coat seems to be tricky.
This is just one opinion. We have some really knowledgable participants here - you are in the right place to get various opinions and choose.
