- Joined
- Apr 4, 2018
- Messages
- 4,202
Sure. Less messy than Bargs.
About to start gluing stuff. Can the 3M be used for fabric to metal? Painted surfaces? Vinyl headliner?
I should have bought the airtex stuff, I suppose. When you get a chance, please let me know.there's a glue for the headliner, if you don't come up with something I'll run over to the hangar and tell you what Airtex sent me when I bought the headliner.
Yes, the 3M 30NF is used to glue the fabric to the frame. Vacuum everything or blow it clean with compressed air, give it a quick wipe with alcohol and the glue goes right onto the powder coat.
Two details about the process, you need to brush it on so that you have adequate film thickness without runs or buildup so it's a bit of a learned skill. 2nd, when you wipe the fabric of excess glue, don't press too hard, it only takes a little pressure to remove the excess glue without squeegiing (squeegy-ing) every last bit of glue out of the fabric.
I'll take a look tomorrow morning at the can of contact cement for the headliner.
If that is the brown hard gunk that was on my frame from the Bellanca cover job, you are right, that stuff is bulletproof. Unfortunately it is not listed as an adhesive for the ACA process. I plan to stay 100% legal so my IA has no qualms signing off on my work and submitting the 337.The factory technique was to attach fabric to metal with Pliobond.
Do you apply the 3M to both surfaces,
I am not using an STC. I am using the TC holder spec. See attached. I think it supports it. Take a look and tell me if you agree.While I agree with that in an engineering sense, do the STCs support it?
Interesting... am I understanding this correctly? ACA suggests applying tapes with super seam or polytack when the polyfiber system applies them with poly brush? I'm going to use the 3m around the skylight but polytack every where else to attach the envelope.... but I'd never considered using polytack for application of tapes.
From my experience this could be nice considering pinked edges don't always seat properly and need to be chased with an iron....
