Well, possibly a solution, but probably not:
I went today to do an oil change today, and decided to attempt to get some crude date points in the process. Decided to go for a flight to warm the oil to make it easier to change. Flew at 1500' and 2400RPM. On returning to the field, I saw the oil as high as 225-230 indicated:
After the oil change (changed from 15w50 to W100), and assuring that all baffling was correct, I replicated the flight exactly and only saw the temp reach 210-215 indicated.
I did have the throttle pulled back more on the first flight near the end the help the temps come down. You can see the lower RPM and lower airspeed in the first pic vs the 2nd.
The only thing I noticed that was POSSIBLY giving me higher temps prior to the change is that I'm not 100% sure the baffle on the left side of the cowl by the cooler was forward. When I re-cowled it after the oil change, I noticed it was VERY easy to get that baffle seated wrong. So I took care to make sure it was 100% correct. So I think MAYBE that could have been a factor. Either way, a near 20 degree reduction is progress. I'm planning to take it on a trip this weekend so we'll see how it goes.
Also, I do believe at least some oil is flowing through the cooler, as it was hot to the touch after the flight. Not as hot as the filter housing, but still plenty warm:
I don't know, maybe I'm way down the rabbit hole here. I just think the temp still seems high for an aircraft with a cooler.
I have the new Vernatherm, but I figured I'd try changing the oil and double checking the baffles before I start throwing parts at it. After this trip if its still an issue, I'll pull the vernatherm and take a look at the seat with a borescope.
