Well it was 77° today so I went for a flight, never got above 190° indicated. I’d call that a win.
Through this process, I believe I came to the root of the problem, that is that my airplane has the wrong cowl/boot cowl on it. Someone feel free to correct me if I’m wrong, but here it goes:
From my research, it seems that 1965-1973 aircraft had a different cowling than 1974-.It appears that change was synonymous with going from dual mufflers that exit out the bottom to a single muffler with a side exit stack. My airplane being a 1967 has the dual mufflers, however it has a 1974+ cowling on it. I think this could be an issue because the 1973 and prior cowling has a sizable negative pressure lip on the bottom while the 1974+ does not.
I can only assume that whoever rebuilt my airplane in the 90’s wanted the modern look of the new cowling, so that’s what he installed, but left the dual muffler exhaust. I am beginning to wonder if the lack of a negative pressure lip in combination with the old dual mufflers exhaust is inhibiting proper airflow through the cowling? I decided to investigate today. I removed the cowling and sure enough, there is a fiberglass “patch” where the single muffler exhaust stack SHOULD exit. Proof positive that my cowling was modified to accommodate the old exhaust. So now I am left to wonder, if I had single muffler exhaust and a more clear path for the hot air to exit the cowl, would I have lower CHT’s and more efficient airflow through my oil cooler? Or to go the other way, if I had the old style cowling with the old boot cowl, would it run cooler then? I do plan to swap to the single exhaust at this coming annual, so that will be a worthy experiment.
Here are some pictures:
1965-1973 cowl:
My Cowl:
Fiberglass “plug” where exhaust stack should exit:
That sure was a curve ball I didn’t expect. Am I crazy or does it seem plausible that this cowling/exhaust combination is inhibiting airflow somehow just enough to cause my higher than normal temperatures?
