What did you do to your bird today?
Got a notification from UPS that my parts are being shipped from ACA! Landing gear U-bolt kit, jack adapters, rear seat and battery box kit. A few days ago Chad said they were waiting on the -34 bolts for the LG kit. I found some at Univair and they were the first parts to arrive. Crazy how I expensive those MS bolts are.... I plan on doing the U-bolt upgrade first. It appears the current set is what it came with from the factory.
Replacing that U bolt should be #1 priority.
The MS bolts range in price - I got $130 bolts for $32 each from Genuine. You gotta shop around.
I think I finally got to the bottom of why my CGR-30 randomly reboots after a landing or turbulence. Digging around through the wiring in more depth and found the screw that attaches the bus bar to the breaker is no longer there which would explain it. It was super annoying because it didn’t seem to follow a pattern. I could do multiple identical landings at the same strip and it might reboot each time, no times or any random amount in between. It just needed enough of a vibration to break the contact and lose power momentarily.
Great catch!
1960 7GC SkyTrac Greenhouse model...w/Lycoming 290....Replacing an old worn tailwheel tire....installing the seat frames and preparing to mount the wings for the 1st time in over 26 years.....much anticipation.....it's running with it chalked but can't wait to do some ground runs as soon as all the functioning control surfaces are back on!!!
Unpacked a newly arrived box of ACA goodies. Did some recon on the LG hardware currently installed. Applied Frost King tape to the inspection covers to prevent losing more in the future. Looks like I'll have to cut some fabric under the strut fittings to use the jack adapter?
More of a what I’m going to have to do to my bird in the near future. A friend was out shoveling around our planes and fell over on the ice with the shovel blade slicing a tear in my fabric. With Stewart Systems would you guys recommend doing the stitching suggested in 43.13 before patching or just glue and iron on a patch like Stewart’s manual says for repairs?
I’d glue a patch per Stewart’s. Looks like the topcoat lifted all the way to the Ekobond. I find the Stewart’s exceptionally good at patching.
