I have - ACA doesn't really comment on pre ACA planes - but if you look up his comments on the Facebook group, you'll see that basically he'll confirm that pre '79 there is no AFM, and all restrictions are listed via placards. He implies that planes were placarded against IFR - but I've not seen one. And while placards are listed in the TCDS, there are none associated with VFR or IFR.
Another factor is insurance and lawsuits. Despite the AFM not being mandatory, and the owner's manual not a regulatory document for the FAA, an insurance company or lawyer might argue that you were operating the plane contradictory to the factory owner's manual.
Really sucks that Bellanca just went ahead and changed the wording in the owner's manual, from what Champion listed. Not only did Champion allow for the possibility of IFR, but many of the early 7 series planes came with an extra tall panel to accommodate a full gyro panel.
Lastly, it seems it should be absolutely no big deal to allow these aircraft to fly IFR. If you look up the details of the individual STC that's been discussed (again on Facebook), it's basically an electrical load test. If you put in a modern transponder, gps communicator, and 2 G5s, your load is less than probably a single old transponder or nav/com. Seems the FAA is now insisting on heated pitot, despite it not being required in the regs ... but even that's easy to overcome
