Citabria is a CAR4a airplane. For those, any can legally be flown IFR.
Decathlon is certificated under different rules. If an AFM says VFR only, you are going to need more than gyros and a sweep second hand.
By the way, POH is different from an AFM, at least legally.
Does ac43.13 cover splicing plywood to plywood with doublers over the seam?
Cut off the bottom of the former to allow clearance from the lower mounting tabs so an an ample sized doubler can be glued on each side of the former. Drill it for the mounting hardware and seal it all up before bolting it back in
A repair of one of the other bulkheads was completed just before I bought the airplane; I believe that the method you described was used. It's held up well for over five years.Does ac43.13 cover splicing plywood to plywood with doublers over the seam?
Thanks!Great to hear it Bruce, I respect the hell out of you for going at it as you have
The Part 23 reg is, let's say, subject to interpretation. ACA doesn't install an alternate static air source switch or valve. It believes, with great justification IMHO, that dual static ports mitigate the risk of a blocked port. You'd have to suffer a really bad day for both ports to ice over (and even then...you could break the VSI face). However, when Ken Bowersox was performing the flight test the FAA test pilot insisted Ken had to install a switch. He used a simple (unapproved) pneumatic toggle switch. That was my plan, too. The FSDO supporting me insists that I must use an FAA approved part.Breaking the instrument face for VSI didn't suffice for alternate static?
The difference is whether the airplane is already approved for IFR. The SuperD isn't, so I must apply for a field approval that authorizes an AFM Supplement that adds flight in instrument conditions.I was going to install one of those pneumatic valves in my 1951 Cessna 170. The 170 only has 1 static port. My IA suggested it. Maybe I should install a Cessna 172 part - will check with my avionics shop. Indeed - not worried about the Citabria give the 2 ports, on opposite sides of the airframe.
