Slipinonfinal
- Joined
- Jan 23, 2019
- Messages
- 230
Sector95,
At this point to help you several points need to be clarified. First as mentioned the magnetos mis-timed could be causing the problem but we did not hear if those were re-checked and verified as timed correctly. Second it was mentioned by Desert7GCBC that a laser temp prob could be used to measure engine temps at various locations. Can you or have you done this? Many A&Ps already have this tool in their tool box. Might serve you well to confirm with this tool.
Based on the fact that your CHT's are coming up as normal I still suspect that somewhere here something is obviously being missed.
Also a question here, you stated earlier that your cylinder head temps as in plural are normal, however with the style gauge you have that CHT is reading only one CHT on one cylinder and not all 4 cylinders. So what are the other 3 reading? and which cylinder is that CHT probe on?
I guess you could follow Bartmans lead here and just plunk down more $$ for the B&C oil filter but that does not get to what is really happening here.
Also Bartman shows a pic of the B&C oil adaptor from the engine facing side of the adaptor. That large cavity and threaded hole is where the vernatherm goes in this oil filter adaptor and the smaller hole is where the oil temp probe goes. As to whether there is a oil passage to that temp probe area that is a pass through allowing oil circulation, I can not say with out grabbing one from a supplier and looking at it with a good flashlight or calling B&C and finding out if there is one. If no answer is forth coming here I can assure you I will make a call to B&C and see what they have to say. There is the possibility of a design issue and it would serve us all well to get to the bottom of it if that were the case.
I will be humbled by anyone coming up with the obvious issue here if that is the case but I don't see this as a simple issue based on what has been said.
Cheers, Brian
Cheers, Brian
