O-235-C1 Oil Temperature
Are you doing aerobatics? If you top off the oil, how quickly does the level go down before stabilizing at some lower level? How are the compressions? Have you ever done an oil analysis?
Haven't done aerobatics on this oil, but when I do it's pretty tame stuff typically. The plane burns about 1 quart per 10 hours or so. Oil analysis always come back in the green, have a long history of them, previous owner was diligent about that. Have a sample from last change that I just sent in, waiting on its results.
Sorry I thought I had already posted compressions. These were done on a roughly 38 degree day in an unheated hangar, if that's relevant.
65, 67, 68, 62
Last year during prebuy in April they were "75 or better". Year before that with previous owner they were 75, 78, 76, 79.
Fun fact, number 4 actually had *zero* compression this year at annual, but turned out that the valve setting was too tight and just holding the valve a little open when the engine was cold.
I don't know how significant it is to have low compressions from a cold engine on a cold day. If I were you, I'd get the engine warmed up and redo the compression test, you may have answered your own question here.
Heya everyone, figure I might as well update you folks on my journey since you've been so kind as to help thus far!
Since we last chatted, I completed a series of the diagnostic steps everyone graciously supplied to me here, including another compression test, and hitting the cylinders with a temp gun after a ground run-up. Ambient temperature was about 80F or so, CHT on #3 read 220 at engine shutdown after run-up.
Cylinder NumberCompression ColdCompression HotBase TempCooling Fin Temp
17575155~175
26461168~175
37674155~175
45462180194
In light of the sudden drop in cold compression since annual, and some scoring on the sidewalls we found during a bore scope, we're going to pursue overhauling the number 4 cylinder to see if we see any improvement, which will likely take 2-3 weeks. I'll keep you all updated!
I do find it interesting that both the cylinders on the pilot's left side of the engine are faring much worse than those on the right, but maybe that's just a coincidence.
Thanks again!
glad to hear you are making progress but #2 is very low also, why not pull and overhaul it too?
I was actually having that internal debate earlier; my hesitation comes from the thought that maybe the cylinders failing is a symptom, and not necessarily the root cause. Just odd to me that these cylinders would wear themselves out in just 500 hours for no apparent reason, but I guess to be totally fair, that 500 hours was over 13 years, so maybe not such a stretch to think they might not fare well.
I'll chat with my mechanic on when I meet with him to pull #4, because I do agree with you, it'd be great to have both done and dusted while the plane is down.
If compression gasses are causing your oil temps to run high, I'd guess that getting both #2 and 4 back into fighting shape would solve the problem.
I've been struggling with oil temperatures on my 7ECA, hoping you folks might have some advice.
Today was 95 degrees, which is admittedly warm, but my cylinder head temperatures weren't out of hand, right around 330 in cruise @ 2300 RPM. Oil temperatures still climbed to redline and I had to pull power back to around 2000-2100 RPM to get the temperatures to start dropping, and even then it wasn't significant.
I did an oil change after I landed, since the oil already had 40 hours on it and I figured having just run so hot it might be wise.
I then decided to fly again after the oil change, now 80-85 degrees, and again in cruise oil temperatures steadily climbed to 235 before I opted to head back and call it a day. Total time in climb and cruise power was maybe 15-20 minutes.
We tested the oil gauge with hot water, seems accurate, so I don't think it's a bad gauge. My aircraft has a Casper Labs oil filter adapter on it, which is where my oil temperature probe screws in. Any chance that might cause errant readings?
At annual, one of my mags was overhauled and both were retimed. Is it possible the previous owner has the timing intentionally retarded to manage temperatures? I don't recall having issues this severe last year.
Or is this normal for O-235's and I'm chasing a ghost?
What spark plugs do you use? I switched from 40s to 38s in my ECA and I swear it runs at least 10* hotter. Not uncommon for it to settle in around 235* on a 100* day after an hour of flying
@Sector95 sorry, late to the thread. B&C is my company. Sometimes we have customers use the Tempest filter with our OFA and get higher temps, then they switch back to a Champion and the temps go back to normal. I have never found a reasonable explanation for this phenomenon, and the Tempest works great 99% of the time. I wanted to mention it in case it helps.
Nice that you are here. I use two of your starters on Cubs (TC was a great help) and if the Sky Tek craps out again we will make it three. Good product!
Perhaps a bit late too, but reacting to the compression values of Sector a bit earlier in this thread, according to Mike Bush the compression test is a not very accurate way of telling you how healthy your engine is, for a lot of reasons. If you have the time, take a look at this link:
To November67,
Mike Busch,
Certainly is savvy however remember that compression checks are still a requirement as he points out and they still can alert you to a maintenance issue with the engine. Compression checks are just one tool in the tool box and other tools can and should be used at the same time. For example spark plug condition, engine monitors can also tell you a bunch if understood and used correctly. I am also a huge fan of engine oil analysis as it is a very economical way of keeping tabs on the heart beat of that expensive beast in front of you.
Cheers, Brian
To: Nbanbridge,
I met and talked with your Father many times over the years. He was a huge asset to the aviation community. Great company that truly deserves its legacy. Great to see you here on this site!
Cheers, Brian
This is the first summer I have been flying my Citabria (7ECA - O-235-C1). On the 100F degree days, my oil temp will rise slowly to 240F or thereabouts. On descents, it can drop 20F in 10 mins or so. On a 95F day, the oil temperature will be 220F - 230F which makes sense to me. Oil pressure always sits around 70PSI. I figure that's normal for the engine. CHT is a steady 330F and EGT around 1300F. I have tracked the temps and pressures since I purchased the plane last December.
